I would like to know if anyone out there has a link to a transparent lock screen. I'm currently running cm 5.0.6.2 with 1.5.1 glass-esque theme with a transparent notification bar. I think it would compliment the overall look on my phone. Any help would be appreciated, thanks.
Have you tired Lockbot Pro (available in the market)? I used it way back when (my pre-root days) and I know it had a decent selection of lock screen choices. I don't know how well it behaves with CM but it might be worth a try.
its pretty easy to make the lock screen transparent if you have ninjamorph. If you have it and need instruction let me know. if not you can reboot into recovery and adb pull your framework-res.apk and I can change out the pngs for you sometime this weekend.
