Root Transparent news/weather widget
T-Keith
I'm looking for a transparent background for the stock Weather widget(2.2). I found a few apks but they won't install. I found a couple .zips but they just for close, I think they are for 2.1.
thanks,
-Keith
You could always d/l Beautiful Widgets from the Market. It has a ton of styles and skins. You can also make whichever style you chose to be transparent. You can make it look EXACTLY like the sense weather/clock if you would like. I was planning on doing that but once I saw how many options there were I decided to go with a different look. I believe BW is 1.95 US or 2.05 US, I don't remember exactly. Well worth the couple bucks for the customization
thanks,
-Keith
Dude "Weather and Toggle widget" has the best transparent weather clock. In fact the transparent clock is thier default clock
Thanks guys, but I'm not really looking for a sense like clock/weather widget, the genie widget is perfect, and the transparent version seems to be available.
MDPI resolution phone: http://androidforums.com/eris-all-things-root/161991-metamorph-transparent-chaos.html
You can just run the MM for the Genie Widget and that's it, if you don't want the rest of it.
If you need detailed instructions on how to use MM, see here:
http://androidforums.com/eris-all-things-root/184359-white-circle-metamorph.html
I know it might be confusing, but the Transparent Chaos zip there is NOT the one you need, I just reused the file to make a new MM for a circular battery theme. Hope this helps...
