ErroneousBosch
http://forum.xda-developers.com/showthread.php?t=1987032
Basically it tinkers with the random number seeder to speed things up.
Some discrepancy Fix '90%' of lags in android (Needs Root) : Android for your reading pleasure.
I put this on my cm7 triumph and have not noticed anything yet even tried some heavy games played same as normal I will give it a couple days and see how it does on battery
I will try it again next time I use cm9 maybe it will work on that better
I disagree. I'm not seeing any obvious differences in CPU clockspeed times.
If this is indeed true, the increased clockspeed times are so miniscule that they are not noticeable on the charts. Smartass 2 gov, btw.
This would be easy to test, if say raising your minimum clockspeed to whatever elevated level you think is causing the effect, or perhaps using performance governor (I wouldn't suggest that one as you will definitely see an extreme decrease in battery life) and just uninstall the apk.
I want to know if the app has to be running continually, or does it just have to be run once at boot (to make the change it makes) and then that change sticks until reboot.
Read the xda post
Read the post sweener put in Fix '90%' of lags in android (Needs Root) : Android
From what it is saying all this is doing is firing off a randomizer at 1 second intervals. Yes that will hold your governor's cpu speed threshold to the upper end. The ranomizer itself is going to use CPU cycles to run so what would make you think the CPU governor wouldn't be affected?
Pffft
