If I were you I would backup, then start with a fresh install of Ver5 that I just posted and see if that takes care of your problem. If not then try a different ROM and see if that fixes the issue. It could be a hardware issue the charge ports are known to go out on these phones. I have never had a problem charging. You can go into Settings>About phone>Status when it is plugged in and see what it says under Battery status.My MT charges while turned off but when I turn it on it don't charge. My USB doesn't show or let me connect to the sdcard on my PC either. Any help with this would be greatly appreciated. Also this happened right after I flashed stock sharp for the triumph version 4.
Hate to break it to you, But the Triumph is a Lemon phone. That means so many things can/probably will go wrong with it. I have a Triumph aswell and mines does the same thing. I've noticed that SOMETIMES luckily placing the USB in slowly triggers the charge. But otherwise The phones messed up. As much as i Love android, I see myself getting the iPhone 4S on release.
The Triumph is known to have USB issues here, mine cannot connect or charge on the computer, no matter what ROM I use. This is probably a port issue, not a software issue.
I've had nothing but problems with the USB port on both my original Triumph and the replacement Triumph i've gotten. It won't recognize when it's connected to a computer so I can't transfer files and it refuses to charge with anything but the USB cable it came with. It will pretend like it's charging when using other cables (charging light turns on, power monitors say it's charging) but it will never actually charge unless I use the original cable.
