AngelicaMD
MY Triumph Is Not being Recognized By Windows 7...I've tried different ports and cables but no luck
I've also tried any cut
I've also tried any cutFollow along with the video below to see how to install our site as a web app on your home screen.
Ok, dumb question... I guess you enabled USB mounting when it popped up on the notification bar when you plugged it in?
If so, did you see any new drive letters show up on your computer?
actually usb mounting didn't pop up at all when i connected it
Does the notification light come on the MT like it's charging?
yes other things connect to my computer's usually detect the triumph and my triumph usually pops up mass USB storage but it doesn't do that it only charges now when connected to pcHave you tried it on only one computer and does other things like flash drives connect to the computer?
it may be that the data pins are dead on the USB port on your MT then. That's all I can really think of. Has it ever connected?
I think you're right...should i call VM and get a replacement?![]()
