Root trouble rooting my evo 4g,please help
roro37
I was trying to root my EVO 4g with gingerbread. I pulled up cmd,was typing what I was told. Then it says copy beta key and paste it. I did and it said invalid key. I know I put it in right. I true to start cmd back up. When I got to and,a lot of stuff popped up. Then o said can I just start at beta key,I didn't know how. How do I start from where I left off or start the CMCC process over,plz help
welcome to the forums!!!!!!!!!!
moved your post to the rooting section
you will have to re download revolutionary and the beta key generator willpop up again. just make sure that it is entered correctly. it is case sensitive. also somebody said that they used notepad and pasted it onto itand then copied it and used that to paste in the comand window.
