Root Trouble Rooting Samsung Stratosphere
jamham27
Hi
I tried to root my phone using the guide on rootz wiki entitled "[KERNEL] [GUIDE] Root Your Stratosphere! :-)"
I got up to flashing my phone, but I got a weird interaction:
user$ --kernel root-zImage
Heimdall v1.3.1, Copyright (c) 2010-2011, Benjamin Dobell, Glass Echidna
This software is provided free of charge. Copying and redistribution is
encouraged.
If you appreciate this software and you would like to support future
development please consider donating:
Initialising connection...
Detecting device...
Claiming interface...
Setting up interface...
Checking if protocol is initialised...
Protocol is not initialised.
Initialising protocol...
Handshaking with Loke...
ERROR: Failed to receive response!
SO the root failed, I assume. Now it keeps saying that the firmware encountered an error instead of turning on. Is my phone bricked? Can I fix this?
Heya! I moved you over to the samsung stratosphere forums where you will get advice from people who know the device well.
I had the same problem until I fully installed the Android SDK and adb (I believe adb is in the pro-tools package, or at least p-something-tools). Once I had done that and made sure that adb could detect the device, then I was able to successfully root mine :-)
