HereticSins
Android Expert
If you search up ics launcher and see there pictures. You can see that white analog clock widget. Is there anyway to get just that widget? Thanks.
Haha me too. And yes because I went through the ics launcher apk. And found the pngs for it. Don't really know what to do from there lol.
That's what I was thinking. Ill try and ill tell you if it works.![]()
Well no luck. It won't install for some reason.![]()
You swaped out the pngs only right? Did you rename to whatever they were originally inside the apk?
I have get android 2.3 few days ago.I feel good about that.
yeah.:banghead:
Okay?![]()
Yeah sure. How would I send them? Just the new pngs right?
This is the one I want.
This is the one I can only find. :/
Ugly looking thing.![]()
