Root trying to root - usb debugging?
ive even uninstalled and installed moto drivers and updated them.
plugged in phone in pc mode..let it verify device. activate usb debug, let it to its thing but still nothing/
Put it in charge only, follow the instructions on installing adb. Once you're in the adb tools directory, run "adb devices" and see if your Droid X shows up as a connected device. If so then you've succeeded in getting adb to recognize your device.
i just did this a couple of days ago. i had pretty much the same type of problems on not recognizing the device. in the instructions i saw someone said put it in charge mode, or even some other modes. what worked for me is the sync mode, then it recognize the device. try all the different connections. regardless, usb debugging is always on. one of the modes should work for you.
edit: this is the link i used that worked for me except i didn't use pc mode. i used windows sync mode i believe. or whatever the other mode is.
http://www.droid-life.com/2010/08/26/droid2-rooting-method-works-for-droidx-running-froyo/
im in the tools directory and there is no adb devices
he mean once you installed adb, you can type "adb devices" on cmd prompt and you should see your device. if device is not found, then you probably need to change the connection mode to something else. try all the settings.
when i go to run...cmd]
and type that it says adb not recognized is not a internal or external command or whatveer
OK. First, you need to add the location of your SDK to your system environment.
I've added "C:\androidsdk\tools" to the "PATH" system variable. So I can use the adb commands no matter which directory I'm in. The simpler solution is to change directory in command prompt to your tools folder (in adroidsdk), put all your rooting files in there and perform the operations from within that folder.
If you're on XP, right click My computer => properties => Advanced tab => Environment variables (at the bottom) => look in the "system variables" section for 'PATH' => click edit => APPEND your sdk folder to the list of directories. Use a semicolon between each directory.
If you're on windows 7 it's even easier; right click Computer => properties => Advanced system settings on the left side.
If you're on anything else, you're done and can't root. Ever!
jk. Someone else will have that answer.
Mine looks like this:
'...whatever was there before'; c:\androidsdk\tools
Next issue.
I'm assuming you've installed the adb interface drivers (you will see ADB Interface in Device Manager) since it shows up in USB mode.
When you're in PC mode (which you must be in to root), you WON'T see the debugging icon in the notification bar. It won't show up.
After you're done with the first problem, you need to run ADB DEVICES in command prompt. If your devices is connected, you'll see a bunch of numbers with the word device next to them.
You should be good to go from there.
Ask if you have any other issues.
GL :D
now that im rooted. the super user ninja guy, when i click on him is anything suppose to happen cuz it brings me to a black screen for that icon.
nah..it's just gonna have the list of rooted apps you have that's enabled. if you have no rooted apps, then you'll see nothing. having the ninja just means you're rooted (kind of). my bro's wife had it, but lost root still. which is why i did the method above to root her back.
I have tried anything and everything and can not re-root my Verizon Droid X 2.2. Anyone in Pittsburgh able to help in person?
Can't help in person but I can help here. What problems are you having? I ran into a few things that were different between the 2.2 leak and the OTA so I may be able to help.
When you're in PC mode (which you must be in to root), you WON'T see the debugging icon in the notification bar... :D
Hmmm... somehow I did it without being in PC mode. When I was following the directions it said to put it in PC mode, and that USB Debugging HAD to be in the notification bar. But when I switched it over to PC mode, USB Debugging disappeared from my notification bar. Still, I figured I knew it was on, so I tried it... didn't work. So then I tried it in USB/Mass storage mode... didn't work. Then I tried it in Charge Only mode... didn't work, when I tried it in Windows Media Sync mode.... it worked.
I have the official 2.2 OTA. I have tried every mode. Somehow it either does not find my device or something about permissions.
Something about permissions is too vague. Can you either copy/paste it or transpose it?
Also, are you sure you have USB debugging turned on?
Strange. I've always rooted in PC mode. I did 2.1 and 2.2 that way. USB debugging doesn't show up in PC mode for me but it shows up in USB mode. Next time I need to root, I'll try it in another mode.
For some reason the latest motorola driver was causing the problem for me when I tried to do it using the easyroot method. When you put your phone in pc mode and you connect it to your computer a cd drive will show up with motorola drivers, install the driver from that "cd" that is the original driver. Also some people said they rooted in pc mode even without the debugging icon showing up, if you think everything was setup correctly give it a shot.
You need to connect to PC in PC mode with USB debugging turned on to root the phone again, but if you have installed MotoConnect driver from 2.1 version, it will not recongnize the Droid X 2.2 in PC mode w/ USB debugging turned on.
To resolve that, you need to download latest MotoConnect driver.
You can download it from below.
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=bda09ec8009a0210VgnVCM1000008806b00aRCRD
After that, you should be able to connect using PC mode with USB debugging turned on.
Hope that helps.
I have Motoconnect 4.7.1. I am so lost now. I have no idea if it is my drivers or if I messed up installing everything.
If anyone is in Pittsburgh, please let me know.
