Help Turn off 4G?
M
MJSisco93
Guest
I live in a non 4G LTE area on AT&T, and I notice when I'm not under wifi that my Skyrocket is constantly searching for a 4G signal. Few questions-
1. Is this sucking up battery life? If so, how do you turn it off if you can? Thanks in advance.
Yes, it will take more juice for the radio to find a signal..I just turn off data unless I need it honestly and it will save you more battery life. Wifi also uses less battery than data
how is it done once you are rooted?
once rooted you can replace the settings apk with the rogers settings apk, or flash a rogers rom..the option to use hspa/gsm is not locked on their version like it is on ours
