I know, it should be easy. But how can you turn off the camers shutter sound? I looked & tried everywhere.
I bought CameraZoom FX for 10 cents when Google was running its 10 apps a day for 10 days for 10 cents each promotion last month. Waaaaaaay better than the stock app. I'd still recommend it at the 2.99 price.
I know you guys probably don't care, but this is actually a "safety" issue. A lot of phone manufacturers are making the shutter sound mandatory now because they want people to be aware of when a picture is being taken of them, to avoid creepers and stuff like that.
visit this link
jjpda.blogspot.com/2011/12/how-to-disable-camera-shutter-sound.html
Are you annoying by the loud camera shutter sound and set to silent mode or volume off did not fix the problem?
Here is simple way to disable it, but your phone need to be ROOTED.
TODO:
1. Download Root Explorer
2. Run Root Explorer
3. Browse thru the file until "/system/media/audio/ui"
4. Click on the [Mount Button]
5. Rename "Shutter_01.ogg" to "Shutter_01.ogg.off"
6. Reboot your phone. DONE
Try take a picture. Even with sound ON, your camera shutter will not make any sound
Email This
BlogThis!
Share to Twitter
Wont let me ...read only file.
If you can get there (i.e. rooted), the sound file is located at /system/media/audio/ui/camera_click.ogg
I couldn't delete it, but I was able to replace it by copying/pasting a silent sound file with the same name using Root Explorer. (Used Audacity to create file - it's in the attached zip file.)
I'm not using the standard home screen, but for anyone interested, I would imagine the same idea would work for replacing the "swipe" sounds with the same file names
Swipe open is located at /data/data/com.nec.android.ncmc.homeapp/files/2.ogg
and Swipe closed is at /data/data/com.nec.android.ncmc.homeapp/files/4.ogg
-Tom
-Tom
