Squadzone has made an excellent tutorial and script for setting up and making CyanogenMod
I am using most of it and making some tiny changes and additions for use with the Prevail
Requirements :
1.OS linux Ubuntu 11.04 64bits ( recommended ) or above
2.2Gb RAM with 3Gb swap or above
3.Processor Centrino Duo or above
4.120Gb Harddisk or above
5.Fast internet connection
First download this file to you Downloads folder
installerBuildRomGalmin.sh
Password : squadzone
Open Terminal
$ sudo add-apt-repository "deb http://archive.canonical.com/ lucid partner"
Enter your password
$ sudo add-apt-repository ppa:ferramroberto/java
$ sudo apt-get update
$ sudo apt-get install sun-java6-jdk sun-java6-plugin
if you get an error
$ sudo apt-get -f install
$ chmod 7777 ./Downloads/installerBuildRomGalmin.sh
$ sudo ./Downloads/installerBuildRomGalmin.sh
say yes or OK to any prompts and Install the recommended packages
follow all instructions that appear,
after Finish, now we goto download repository
still on Terminal
type
$ mkdir -p ~/cm7/system
$ sudo su
$ sudo curl https://dl-ssl.google.com/dl/googlesource/git-repo/repo > /bin/repo
$ sudo chmod a+x /bin/repo
$ exit
$ cd cm7/system
$ repo init -u https://github.com/CyanogenMod/android.git -b gingerbread
Enter you name and email when asked and say yes to color display
$ repo sync -j32
THIS WILL TAKE A WHILE TO FINISH
download this zip file, unzip, and copy contents into /cm7/system
prevail_cm7_config.zip
merge all folders and overwrite any files
still on Terminal
type
$ ./vendor/cyanogen/get-rommanager
(ROM manager does not support our phone, but we need this file for the build to work)
$ source ./build/envsetup.sh
$ lunch full_prevail-eng
$ mka -j4 bacon
WHEN FINISHED YOU WILL HAVE A FOLDER
cm7/system/out/target/product/prevail
WITH A BUNCH OF GOODIES IN IT, LIKE YOUR ROM AND CWM(YES THIS MAKES CWM FOR YOU)
THE ZIP FILE update-cm-nightly-signed.zip IS THE ROM
THIS IS FLASHABLE IN CWM
I USUALLY TAKE THAT ZIP UNZIP IT AND PUT A MODDED INSTALLER SCRIPT IN IT, REMOVE ROM MANAGER, AND ADD SOME LAST MINUTE FILES AND GAPPS FILES AND SUCH
I BUILD THE ROM ODEXED BECAUSE WHEN I AM DEBUGGING THE ROM AN ODEXED ROM BOOTS SO MUCH FASTER THE FIRST TIME AND I AM CONSTANTLY REFLASHING AND WIPING TO TEST NEW
SETTINGS
IF YOU WANT CM7 TO BUILD THE ROM DE-ODEXED FOR YOU
EDIT THIS FILE IN TEXT EDITOR
cm7/system/device/samsung/prevail/BoardConfig.mk
ON THE BOTTOM OF THE FILE LOOK FOR THIS SECTION
#JIT / Optimizations
WITH_DEXPREOPT := true
JS_ENGINE := v8
Add # so it looks like this and save the file
#WITH_DEXPREOPT := true
JS_ENGINE := v8
IF YOU HAVE ALREADY COMPILED THE SOURCE AND YOU MAKE CHANGES TO THE BoardConfig.mk YOU WILL HAVE TO DO THIS FOR YOUR NEXT BUILD
$ make clobber clean
$ mka -j4 bacon
I WILL BE MAKING CHANGES TO THE CODE FROM TIME TO TIME SO YOU WILL NEED TO DOWNLOAD THE NEW SOURCE FROM
https://github.com/hroark13/prevail_cm7_config
If I have helped you, and you like my work, please click on the Thanks Button and give my thread a rating by clicking on the stars above.
If you would like to buy me a beer cofee, you can click on the PayPal button
Requirements :
Open Terminal
Enter your password
if you get an error
still on Terminal
type
$ sudo su
$ exit
$ cd cm7/system
$ repo sync -j32
still on Terminal
type
$ mka -j4 bacon
SETTINGS
JS_ENGINE := v8
JS_ENGINE := v8
$ mka -j4 bacon
