All thanks to PlayfulGod who has made this possible.
Most preferred method:
Download this zip:
Flashable zip
Steps:
1.) Put the zip in your SDCard.
2.) Reboot into current recovery.
3.) Flash the zip.
4.) Reboot recovery!
Done
Method 2:
Downloads:
1.) Grab this: CWM-A70
2.) Then this: Recovery.img
Steps:
1.) Extract the zip file to a folder of your choice.
2.) Rename the downloaded recovery to "recovery5.img" (or whatever you like)
3.) Turn off your mobile.
4.) WHILE HOLDING THE CAMERA BUTTON, Connect the usb cable to the phone (and PC too ).
5.) Open cmd prompt and cd to the directory of your extracted folder.
Example:
If have extracted to D:\CWM-A70, then use:
6.) type:
7.) type:
8.) Done. Check the new recovery or post here for problems
Alternative Method:
(Using ADB, not fastboot. All thanks to sam. Tested by aditya)
Latest RZRecovery:
Hey guys, here's the latest RZRecovery for A70:
Huge thanx to Raidzero (aka RZ ) for his efforts..
The old RZRecovery didn't have working backups, this one works perfectly! (Observed till now.)
Methods:
1.) Using CWM recovery:
Download this zip: RZRecovery
And flash using CWM
2.) Using the fastboot method:
Extract the RZR.img from the zip and flash using fastboot (as specified above).
P.S. Unlike in CWM, buttons for RZ are:
Home (center button) for selection.
Power for back.
And volume keys for navigation.
Download this zip:
Flashable zip
Steps:
3.) Flash the zip.
Done
Method 2:
Downloads:
Steps:
Example:
Code:
D:
cd D:\CWM-A70
Code:
fastboot-windows flash recovery recovery5.img
Code:
fastboot-windows reboot
Alternative Method:
this is the cmd to flash recovery through adb
mount -o remount,rw -t yaffs2 /dev/block/mtdblock1 /system
cat /sdcard/flash_image > /system/bin/flash_image
chmod 755 /system/bin/flash_image
mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak (if it gives error message here, simply proceed to the next step)
mount -o remount,ro -t yaffs2 /dev/block/mtdblock1 /system
flash_image recovery /sdcard/your recovery name
reboot recovery
The phone will reboot now.
NOTE: If you get this error after step 4
failed on '/system/etc/install-recovery.sh' - No such file or directory
issue the next command
Latest RZRecovery:
Methods:
And flash using CWM
Power for back.
