Root [Tutorial] Easy PRL change without using CDMA WS
Once you get it write that sucker down so you don't forget it because it will not change until you upgrade your handset.
ok, why would anyone change it or want/need to change it and what would changeing it do????????
Change it to something easier to remember. lol :p
As far as I know it doesn't affect anything if you change it. The only reason I know that it changes when you change handsets is because it changed when I changed mine. :D
I think I'm a pretty tech savy guy and absolutely read and follow instructions. I need help, the code ##7678# does not work for me. I get a recorded message that tells me that the number or code entered is wrong and to please check it and try again. What should I do? Anybody have any ideas because I'm stuck. :confused:
are you rooted what rom are you on,ctmod3.6?
if so you have to make a backup and then flash 2.5 or half ass rom to phone and then follow steps and then restore to get back to where you are now.
there is no hidden menue on 2.6 and up and most other roms.
You need to be on a Rom that the ##7678# code works, like CTMod 2.5 or Half Ass Rom 1.0 or 2.0.
someone on the prevail no rooted forum said this and wonder if would be good to try while on 2.5 or 1/2 ass
Increased 3g speeds by changing
Home orig. vocoder = 13k
Home page vocoder = wild
roam orig. vocoder = 13k
3g speeds went to an average 0f 230-290kbps download to 600-980kbps and uploads from 80-150kbps up to 480-650kbps
Enter settings from dial pad ##3282# enter msl, select edit [enter msl] select advanced and change vocoder settings
I tried this tweak a few months ago. I didnt notice a change in 3G speed. But it never hurts to try if itll work for you(well it could hurt a little:) )
I guess I'm all turned around I have a warp but can't u just use s manager go into build prop and change prl and save ?
Would this still work on ctmod. 3.75?
I can't get the device to 'unlock'. I chose SAMSUNG Android USB Diagnostic Serial Port, then "In the SPC box (top left) enter your MSL number, then click the blue arrow next to SPC". It just keps saying 'searching for devices'. :confused:
What ROM are you using?
