Root [Tutorial]How to flash ROMs/Flashable zip Via CWM
Dark GOD
Member
As per Many newbies Doesn't knows how to flash via CWM. I have made clear Way to install and flash it Via Recovery..
Here is the tutorial For u how to flash/Burn Flashable zip.
Prerequisites :-
-Micromax A75
-Recovery.img Modded By varun.chitre15 Download Recovery.imghere
-Spflash tool
-Package of Update provided by micromax
Procedure:-
-Open SpFlash tool And load Scatterfile u can see that file in orginal Mmx package..
Un tick all except Recovery.img And select recovery.img Which u downloaded it.(Cwm recovery)
Be sure that u have put ur mobile in use debugging (setting->application->development->usb debugging)if its not tick it..
Now Press f9/download in spflash tool Mobile should be turned off.. And plug it To usb via Cable
After it's done u can see Spflash tool mess Download completed..
now unplug the device from Usb turn on to Recovery Mod
By pressing Power off button,volume+ button and home button in series
U can see Now CWM recovery And its Done
Now u can flash any flashable zip files..
Note:-When u flash any ROM
Be sure that u have down This
-Wipedata/factory reset
-wipecache partition
Then go to advance Option inCWM
-Wipe Dalvik Cache
And now Select ur ROM or Any flashable zip file
it seems like this Install zip Form Sdcard Click it browse your sdcard and Select your Favorite ROM :p
after its done go to advance menu And Give fix Permission!
voila!! :D
Hi Dark God,
Where do i get original mmx package ? kindly give the link as i need to flash my mobile. currently using UB-A75-2_V3.
Thanks in Advance
Elavarasan S
Prerequisites :-
-Micromax A75
-Spflash tool
Procedure:-
-Wipe Dalvik Cache
voila!! :D
Does this method needs ROOTED phone or it can be done on UNROOTED also. As i have got the latest updates from MMX Service Center today and before rooting i want to have a back up of it so that we can have that as a backup and also it can be used by the DEVs for the further development so if i flash recovery by this method then i can have a backup of the STOCK ROM through the recovery. I dont know if its possible or not so please let me know that also that if i flash recovery by this method do i be able to take a backup of the STOCK ROM which will have all the things like BOOT.img, SYSTEM.img and all the other files.
The updates what i have got have this changes in about phone
Android version
2.3.4
Baseband version
MAUI.11AMD.W11.37.SP.V2.F1.P1,
2011/11/22 22:33
Kernal version
2.6.35.7
Build number
[SW VERSION] A75_0201V3021 ( this one was previously 3006)
[HW VERSION] A75_Mainboard_P3 ( this one was previously P2)
The change what i have observed is
Build number
So please let me know so that i can have a backup of it. If you have any other easy way to take the backup then tell me i will try that.
Prerequisites :-
-Micromax A75
-Spflash tool
Procedure:-
-Wipe Dalvik Cache
voila!! :D
Can anyone tell me that is the scatter file same for Micromax A75 of any version as i have the latest updates and there is some changes in build version so if i want to take the backup of stock dump by sp flash tool and after that want to just flash recovery by Mastermind which supports sd ext 2 can i use the same scatter file provided in the Micromax A75 New Ver.rar from Sendspace.com. Please devs let me know can i do that so that i can get the backup and provide it to all and we will have a new updated version of Micromax A75 as well as can i use the recovery provided by mastermind or i need to have the recovery provided by varun only.
Prerequisites :-
-Micromax A75
-Spflash tool
Procedure:-
-Wipe Dalvik Cache
voila!! :D
Have tried the method of getting the Stock ROM dump by the method provided in this web site
Smartphone Reviews: Creating a ROM dump of your MT65x3 device
as i m having the latest updates provided by the MMX SERVICE CENTER and these are the details
Android version
2.3.4
Baseband version
2011/11/22 22:33
Kernal version
2.6.35.7
Build number
Build number
but cant do it as its was not detecting the phone so finally dicided to flash it with recovery and then get the backup of the Stock ROM and had BACKED it up successfully. Now i have the new updated backup of MMX STOCK ROM... Finally did it had tried to install ADB SDK JDK and installed them after working whole 1 week and had got the scatter files of my phone i was so happy to see that scatter file and all the things were also working till the sp flash tool work started and when it has to backup the STOCK ROM it dint detected the phone. I was trying to that since from morning and at 4pm concluded that its not going to work as if had tried to work with sp flash tool for more then 5 hours had kept the phone attached once 30mins next for 1 hour nad then tried randomly tring to press other buttons also but was only waiting for sp flash tool to detect the phone but it dint so had flashed the lastest recovery by mastermind which supports sd2ext using sp flash tool and had successfully flashed it and then took BACKUP of STOCK ROM. Its 270mb with 6 files in the backup folder.
Thanks to Maaster Mind AmarZo T DAs @Dark God Ninad Chaudhari Varun Chitre and all others who have supported me in getting what i wanted... Thank you buddies...
Hey now i need the super user zip to flash via recovery so that i can have my phone ROOTED so buddies please provide me links to download it. Waiting for your replies.
Prerequisites :-
-Micromax A75
-Spflash tool
Procedure:-
-Wipe Dalvik Cache
voila!! :D
recover.img is not working
hey guys sorry actually my phone wa mmx bolt A089 i got a problem with my phone , i was unable to mount my emmc i was unable to start my phone i got bootloop if i install custom rom it is installing i tried 3 or 4 roms it installed but not starting it got loop at booting
