Help Two new issues
Myronbg
Member
Over the last couple of days I've had the following problems: (1) if the screen is off for a period of time (an hour or so) it does a full shutdown and takes a full 10 seconds to reboot; (2) the screen, while I'm doing something (angry birds, email, web), flashes to the home screen and back to where I was. I haven't installed anything different (at least I don't think so)
I have had mine freeze after clicking on email. So i shut it down and it shut off without asking what I wanted to do.It booted up alright and everything is normal now.
One thing that I've done, and it's probably dumb, is run my bedside app. Provides the time in a settable dimness (20% for me) & stays on. Hitting the back button brings up the home screen.
Hi,
There might be an app conflict with Honeycomb.
there are not many apps that are compatible to Honeycomb 3.0 at the moment.
I do not install many apps on my tablet and I monitor the Tablet's behaviour after installing a new app to make sure that the tablet is running correctly.
cheers :)
Hi,
cheers :)
Thanks for the comments. What ever caused the weirdness has seemed to go away. Could be just a full power on / off. I'm going to stop the use of the bedside app to see if the power on after sleep change.
Looking forward to 3.1!!
