Father Guido
I'd pull mine, but it's not stock anymore and I don't really recall what I've changed ;(Can anyone point me to a complete stock backup or ROM for the Realm L620? I'll be happy with just the systemEXT4.tar.a
Time permitting, I can still pull my /system for you. I'm pretty sure that all I did was make su a system app. Froze many with TiB, but they are still there. If interested, gimme a place to put it.Well I still thank you, Sir. I hope someone still does have a full stock available sonewhere. I'd have done so and posted myself but there didn't exist a custom recovery at that time to backup & factory reset wiped all apps TB backed up as well. SD capability on this suks, Lol.
It's not 100% stock, but check your inboxThank you Sir! Upload to either or a similar site: Drop box, the Box, ect & post a link (pm me if you don't want a million ppl accessing it). If using drop box, I'll notify you of finished Download so you can disconnect link &/or delete to save space if desired. And Thank you again
You're welcome, but please let me know how you fare. Hopefully you can dd it for "nearly stock' & install the OP's recovery. Works perfectly on the Realm. If I were "the MAN," I'd edit & repack it for the VS450PP. I tried, but failedDownload successful, you are THE MANN!! And thanks again.![]()
What does "until I hit a stump" mean? The recovery that I edited and linked here doesn't touch your /boot.img at all, let alone /aboot.I successfully flashed your recovery and it worked flawlessly until i hit a stump. I can no longer boot in, just get a secure boot error then a black screen.
Can you please provide me a link to your stock aboot.img
I'll do my best to pull aboot.bin later today and link you to it. Is that all you need?I already have a stock boot image. I need an aboot.img
I was getting a secure boot error before that. I don't really know if that's all I need.I'll do my best to pull aboot.bin later today and link you to it. Is that all you need?
Sorry, I thought that you knew. I am on the vs450pp (exceed 2)EDIT: Just to clarify, this is for the Realm (LGLS620), not the Exceed 2. You didn't really specify which device (or I missed it).
Cool. Did you use adb or fastboot to restore it?Thanks, the aboot did the trick
I dded the img into the aboot partition. I'm in download mode atm setting up the flash tool to do a kdz backupCool. Did you use adb or fastboot to restore it?
BTW, is anyone else having issues with USB debugging on the VS450PP? Every time I plug one of these in, I "have" to go to PC connection/Select USB connection method/ then use "Internet connection" and select ethernet or modem to enable debugging. Even if one is previously selected, (and I reboot or unplug) I have to switch to one or the other before debugging is enabled again. Most other LG devices enable debugging in MTP (or even charge mode), but not these.
I've encountered similar behavior on the LG-G2 (VS980). Beginning to think it's a Verizon specific device issue. I *can* get to debugging, just a PITA is all....
What would that do and how would I flash it, i can't dd now because the device just reboots after the errorHave you tried a "bumped" kernel?
