Getting into download mode is as simple as powering off the phone, then plug in to the computer while holding the volume up key. The real problem is that there is no kdz available for the realm, so it's of no use unless you can locate it.
Odin is for Samsung devices, LG flash tool is the program for flashing this phone.
I understand that you are new and want to learn. I just told you 2 things that you could have found on your own. Much of what you seek has been linked/discussed right here on these forums. I'm of the opinion that you want to fix your device and following a guide teaches nothing.
You will need to search and read until your eyes bleed to truly learn. You will almost surely brick a few devices in the advent
You will need to search and read until your eyes bleed to truly learn. You will almost surely brick a few devices in the adventure. It happens to all of us.
That said, I wish you well and will gladly assist if you put in the time to grasp the concepts.
I am familiar with Samsung and using odin. I am willing and want to learn lg. My problem is I'm not sure and have research to see if you can use odin with lg.
I havent had any luck getting it into download mode that's why I asked. If lg flash tool will do the trick I'm all for it. Not familiar with it. Looks Greek to me. I tried something with it earlier and an SD card and it didn't work... Recovery isn't mounting sd card. Idk why don't know how to make it mount.. Phones settings says it is mounted that's why I'm confused. I read the adb instructions and follow the steps but I'm apparently not doing something right.II don't remember the issue I'm having... Oh yes I was trying to sideload a keyboard app with adb... Told me keyboard.apk was invalid. Researched that and tried putting it in the adb folder ( maybe put in wrong place, misunderstood) and still nothing... I was initially thinking if I could get a keyboard on the device I might could easily fix my issues... Either way having it wouldnt hurt.
I did not read the entire post
I have been going at this since about 7am ish and I'm tired. What I did read maybe I didn't comprehend...? I'm not even sure my long winded post made sense lol. Please advise if you are able
