Help TWRP ISSUES
I know when I first started compiling twrp back when, I had the problem of holding the buttons too long trying to get into twrp and wouldn't be able to get into it. Cwm seems to not care if you hold both buttons too long, but twrp is a little picky. What I do now is power completely down, hold volume down and power, then as soon as I see the factory reset image I let go of power and keep holding volume down until twrp boots.
You probably already know this, but I figured I'd still throw it out there.
Oh my god you fixed my problem!!! Thanks so much man I was booting into twrp with volume up and power but doing it your way is successsful (: finally after months of trying someone comes through thank you so much!!
There is your problem... Its volume down and power
The one thing I never thought it would be... Guess I should have started from the very beginning...
Glad to hear that your issue was fixed! :)
Sorry I couldn't find the solution.
Well my friend thanks so much gor giving it your best shot(: but i have another problem i flashed the cm12 rom 3/16 build and i flashed the apn fix along with it but when i reverted back to my zv5 rom i had no lte and my signal keeps disconnecting from the network (big issue) plz someone help me(:
No one has a 100% sure fix for this issue yet. The only thing I can say is to follow this thread linked below, and try some of the fixes that people have gotten to get their lte be back.
http://androidforums.com/index.php?threads/909213/
