Displacedmic
Hi guys,
I have a rooted EVO 4G theMikMik ROM android 2.3.3
I am having problems with my texts. I can receive texts no problem but can't send them out. I use handcent but i have the same problem with the stock messaging app.
When i send a message, the screen goes blank, then pops up. then my signal bars briefly vanish to an X (the symbol for no signal) and then come back. The messages just sit there perpetually with the sending circle spinning.
I did some googling and tried the following: rebooting, removing the battery, removing the sim card, clearing cache, reinstalling the app.
None of this works.
Do any of you have any suggestions? I suspect my simcard might be going bad but this is the only symptom - voice, data, bluetooth and GPS all work fine - just no outgoing txts
any advice would be most appreciated
thanks!
None of this works.
thanks!
