savetheknot
Member
Hi. I'm new here (just registered a few seconds ago). I did all the steps to root my Ascend, but the phone never rebooted. I went thru the steps twice. Is this common? Where do I go from here?
reboot n try again and/or read my reply to your thread.Hi. I'm new here (just registered a few seconds ago). I did all the steps to root my Ascend, but the phone never rebooted. I went thru the steps twice. Is this common? Where do I go from here?
pull the battery, do all the wipes again n reflash. That dont work find another ROM.phone wont go to recoveryy need help its stuckk on huawei screeenn (vol up send and power)
Toke: Can you add this to your Cm7 Guide?
Without MetrOFF - These settings are for cm7 to get MMS working.
First you have to go to the Voice Dialer, Say "Open Apns". You might have to say it and try different pronunciations for it to work but, Don't give up! Then once you are in there make sure you delete all the other APN listed there. After you've done that, Create the new one. Make sure you have the dot on green before you exit it!
Sometimes you might need to reboot and re-check it. It does work.
Edit: I also am now getting more bars. It is not showing none as it previously was.
APN: #777
Proxy: proxy.metropcs.net
Port: 3128
Username: <Not set>
Password: <Not set>
Server: <Not set>
MMSC: http://mms.metropcs.net:3128/mmsc
MMS proxy: <Not set>
MMS port: <Not set>
MCC: 310
MNC; 16
Authentication type: PAP or CHAP
APN type: default,supl,mms
I have used this with more than one person. I can send and receive with no problems. ^.^ Thanks to everyone who helped me get this information together:
Pip2kk
Tokenpoke
and Isaac for making Icarus and helping us figure out how to get MMS with that too (I used those same settings but with #777 as the APN instead of <Not set>)
Don't you hate that Roaming Indicator Sign? LOL. If you've already flashed MetrOFF, You'll have to do a full re-flash of Cm7. Make sure to back-up if you plan to do this. ^.^
thanks i hope so everything else on it works fine just wont read the card if i could get it to read the card i could flash to 2.2 or like cm6 im afraid of cm7 they say you cant use mms on it and i use mms all the time but i need to at least be able to get a flash player installed cause im wasting my netflix membership without a flash player lol
yeah i read somewhere that you could use the metro pcs on the cricket i was trying to go off a video on youtube YouTube - ‪HOW TO FLASH MetroPCS or CRICKET Huawei Ascend to ANDROID 2.2 (STEP BY STEP)‬‏ thats the link to the video and i think it would have worked but somehow made it so my sd card wont read on the comp i fklashed back to stock and still nothing it sucks![]()
I very knew to the this part of the tech world and I dont know what i should decide on. I have a rooted Froyo 2.2 Huawei Ascend(MetroPCS) and I want to know if i should either get CM6 or CM7 or PlayfulMod. I have read up on each of these ROMS and I know how to install them already, but I dont know which is the best so can SOMEONE HELP!!!!!
thanks that really helped me out a bunch and if you find something better let me know lolwhy not try all of them,
and by the way, you know CM7 has 3 awesome builds
(PlayfulGod, Kmod, BobZhome)
In my opinion if you want froyo than CM6, Its 10x better than PlayfulGod 2.2 stock rooted ROM, because CM6 is really modded and stuff and faster.
But overall just try all of them till you stick to one, flashing doesnt take long, i flash a new rom every week lol. But if you really want my opinion my best bet would be CM7 BobZhome 7082011 Build, Very smooth and fast, no problems that i found yet.
EDIT*
P.S: Try to put this kind of thread under the section of All-Things-Root, up at the top!
ok last post lol i keep getting a process android process media force close pop up after i boot is that normal?lol alright, also if you really want a customized pre-set ROM than Kmod would be it, but it kinda lags but what ever, and hope you enjoy the forums! Also read the Edit i put in my first reply![]()
