CyanogenMod7 port (cm7)
READ ME BEFORE DECIDING ON YOUR ROM!!!!!
CyanogenMod7 (CM7) (DEVELOPMENT CREDIT FOR ROM GOES TO ISSACJ87, FOR CONTACT INFO ON DEVS PLEASE VISIT THE WIKI
Main Page - Prepaid Android)
Overview- CM7 is a custom port of Android 2.3 Gingerbread. it is not expected for Huawei to EVER release 2.3 for the ascend. CM7 is a work in progress as of today (4-19-2011) and some things are not worked out but will be in the future. future updates for CM& will be free but priority will be placed upon new customers first. i will alert you to any updates via email to set up appointments.
Features-
Brand new Boot screen no more metro pcs stuff.
All Bloatware (metro cps stuff, boingo, etc) removed
3x faster than stock
Option to over clock (speed up) cpu to 710mhz from 600mhz
Stock with 2.3 launcher.
Many User Interface options
Apps2sd move select apps to the sd card to free up phone memory.
Power Control in the drop down status bar (turn on and off at will: wifi,bluetooth,synch,gps. Adjust: screen timeout, brightness, ringer settings. other options available)
Built in task killer (app drawer- menu button- manage apps)
New app- DSPmanager: adjust volume output for louder speaker and earpiece volumes.
New app- Car home: for hands free use. maps, voice search, voice dial and navigation all in one.
New app- Books: read your google e-books
New widget- News and Weather; show the weather for your area and news headlines on your home screen.
Theme Chooser- choose form three themes pre loaded into the rom
Other minor apps and widgets
ADVANCED USER APPS!
Terminal: a terminal emulator. fi you don't know what this is please don't play with it.
RomManager; manage your rooms and clockwork mods. again, if you don't know what this is don't mess with it.
Dev tools: DO NOT PLAY WITH THIS UNLESS YOU KNOW WHAT YOU ARE DOING!
Cons (all issues are being worked on expect frequent update notices) :
USB mount doesn't work on MAC (fine on PC)
Some apps will not run on sd card.
_________________________________________________________________
install CWM 3.0.0.5 from the app RomManager (free on market)
download these files-
cm7
http://www.mediafire.com/?1svp059s8hgibx7
gapps-
http://android.d3xt3r01.tk/cyanogen/gapps/gapps-gb-20110307-signed.zip
move the .zip from downloads to the main area of your sd card (if you download from your phone) using file manager.
alternatively you can plug your phone into your pc and move it manually by dragging from the download folder and dropping it in the main area.
backup your contacts to your sd if they are not synched with google.
go to contacts, press the menu button, select "more", select "manage contacts", select "backup to sd" and press ok.
Boot to cwm VOLUME ROCKER UP+CALL BUTTON+POWER
USING THE TRACK BALL
go to backup/restore and select backup.
reboot phone and connect to usb
copy your sd card a folder called "sd backup" for safe keeping.
power off phone and reboot into cwm (VOLUME ROCKER UP+CALL BUTTON+POWER)
use your track ball to select (in order) the following commands
wipe data/ factory reset
wipe cache
advanced
wipe dalvik cache
press the back button (the arrow) on your phone.
under mounts and storage, format following...
boot
data
system
cache
install .zip from sd
chose zip from sd.
choose cm7.zip
choose gapps-cm7.zip
phone will do a bunch of crazy stuff for a few minutes after each .zip is selected
press back on your phone
select:
mounts and storage,
format sd
select:
advanced,
fix permissions
restart system now.
METRO USERS ONLY!
after your first boot and setup download the mms fix called metroff and place it in the main area of your sd card.
return to cwm and flash the metroff mms fix
http://techygeek.org/media/MetrOFF-v1.3-MMS-GB-Edify-CM_ASOP-No_Roaming_indicator_Off_signed.zip
flash it simply by selecting "install .zip from sd, choose .zip" and choosing the metroff.zip
IF YOU ARE ON WINDOWS AND HAVE USB MOUNTING PROBLEMS HERE ARE THE DRIVERS
http://www.mediafire.com/?31l1w9gnv6dolkg (THANKS TO ONESUMMER... FORGOT NAME WILL FIX LATER.)
OPTIONAL DARKTREMOR A2SD TO REPLACE GB A2SD.
if you wish to move all the apps and widgets on your phone just like with icarus you need to install the DarkTremor a2sd script.
download the file....
http://www.facebook.com/l.php?u=http%3A%2F%2Fwww.darktremor.info%2Ffiles%2Fa2sd%2Fdtapps2sd-2.7.5.3-beta02-signed.zip&h=66faa
and copy it to your sd cards main area where you put the rom, gapps (and if metropcs) metroff.
copy your sd card contents to you pc
unmount and disconnect the phone from the pc.
hold the power button until a menu pops up and select "reboot" then "recovery"
once in recovery mode select "install .zip from sd card
select the DTapps2sd zip
when its installed go back to the main menu of CWM
scroll to and select "mounts and storage"
select "format sd card"
go back to the main CWM menu and select "advanced" then "partition sd card"
i set mine at 512mb with a 32mb swap.
reboot your phone
after boot please look in the Icarus 1.1 section to get a feel for A2SD commands in the terminal emulator. i ran the ones listed there for my set up but have been told that the apps are moved when you flash the .zip. a good way to check is to just peek into Titanium Backup and check memory use.
