jcmurp
INSTALLING CLOCKWORKMOD (CWM)
Download the cwm.zip---------> CWM Recovery.zip (Thanks to Jazzette for this from her icarus 1.1 guide)
make sure usb debugging is turned on (menu button, settings, applications, development, usb debugging)
boot your phone into debug mode (fastboot) press, in order, VOLUME ROCKER DOWN+END (HANG UP)+ POWER. your phone will stay at the huawei screen. attach to pc using usb cord.
open the cwm.zip and extract the files
open the cwm folder
open the following files (you may see the dos box open briefly, this shows it worked all file are labeled according to os, choose for your os)
adb
fastboot
install recovery
unplug your phone from the pc and remove the battery for ten seconds.
boot to cwm VOLUME ROCKER UP+CALL BUTTON+POWER
you should see a black screen with green text. you now have cwm
Ok need to know am I doing something wrong. I have rooted the phone prior to this using gingerbreak and I get all the way to the part where I am installing the three files adb,fastboot and install recovery. But when I get to install recovery it just says waiting for device...Did I miss something as I am booting it back up by pressing volume down,end and power and holding them for a few seconds after the Huawei screen comes up
I am working on installing CM7
thanks
