Root ultimate ascend customization guide.
i need some help my friend rooted my gfs huawei u8160 and its a horrible mess
theres no wifi,cant make calls and the process com.android phone has stopped unexpectedly.please try again comes out like every few seconds.
i dont have much experience with androids so can someone help me
its also on cm7 (1.0)
and it looks like he didnt back up stock or what ever it is you have to do.
can some one please guide me step by step im totally lost.
if possible i would like to put it in its previous state before rooting but a fix is good to.
please help
please help
Welcome to AF kero55:)
Couldn't find and option to just fix the issue-so as you had stated restoring it would be an option also.
[GUIDE]All Huawei new&old phones-Install Stock Rom-Full Reset - xda-developers
I also was able to find this which may be useful in repairing the device
Huawei U8160 - Mobile Phone Manual, Cell Phone User Guide, Smartphone & Tablet PC Manual Guide - InfoLinkBooks.Com
Hope this help!:D
It Worked, i Downloaded z4. but after trying run it, it reset, and took off my service.. is that suppose to happen?
No it shouldn't have mess with your service at all. Go to ROM manager from the gplay store and download the app. Put recovery on your phone. Lots of options. Then we will work on why you lost service . Wt:(
ok thanks it worked you the man!
ok since your a wiz ill ask you to help me with another problem my friend download a rom for his huawei m835 it looks like it was the wrong rom or something after the update. the phone doesnt turn on when i plug in the charger it just the red and green lights blink like crazy.
Have your friend check over here:http://androidforums.com/m835-all-things-root/
Might be able to find the answer or solution. If not PM me:)
Okay soo i used z4 again and rooted my phone and got service back, and did most of the steps. But i might have deleted the wrong things.. to be excaly, i may have lost my contacts.. any way i ould get them back? They are on my gmail saved ..
And i kinda cant open market either, if you can pease give me a direct link?(:
All your contacts should restore auto if you use Gmail-lways have for me after it is finished syncing.
You install gapps:confused:
https://www.box.com/s/c673d80d0b7badd65356
