Not sure if this is what your looking for but take a look at these:I'm going on a year with my bat.... and its loosing juice crazy fast. Can anyone tell me the best place to find an extended battery?
THanx
Still using the stock battery going on almost a year now. I simply toggle data on/off during the day using this widget: https://play.google.com/store/apps/details?id=it.miabit.android.dataonoff. I've noticed while I'm sleeping the battery will reduce by less than 10% if I turn off data at night. That's for about 7 hours of sleep.
Those ebay extended batteries are trash. I tested and tried all the major ones on the bay and all of them started loosing capacity and dying faster over the span of a few months. You get what you pay for. Granted you will get a few months of extra battery size but it wills tart going downhill and you will notice that your stock Samsung battery lasts longer than your extended one. My suggestion? pay the money for a legit Samsung extended battery. 30-40 bucks on Amazon or the Bay. That and turn that damn Vampire blood sucking LTE off whenever possible.![]()
Samsung?
