the oclf im disregarding, but the devs had said they would consider voodoo support in future or seeing if the kernel would work with z4mod or other lagfixes. their goal is to make a stable kernel and believe that the hummingbird processor can be pushed to 2.0 ghz safely.
they do it by ocing the gpu and cpu and from the growing vibrant thread at xda people are reporting good results with use, although the battery was reporting a *tick* too hot for what id like to see from daily use.
i tend to think that once it moves to more testing and goes beta if it looks good then someone will port it over. i saw in the devs forum that wicked beav was asking about the code and they said it would be posted as soon as they move past testing.
basically if its good, and worth doing, we ll get it...thats the way i look at it.
