dibs ODDJOB
From reading several people's battery usage details, I think one of the problems seems to be cell standby%. Mine was very low compared to the OS usage. You can call *228 and press 2 to upgrade your roaming capabilities. Do this at your work and home, where you are generally at most of the time. The battery is strained more when it is struggling to find a good signal.
Glass half-full view:
This phone is so thin and light, adding an extended battery isn't as much of an issue as my previous phones.
Edit:
Not saying this will cure your battery problems, but its worth a shot.l
Edit:
) , unless I'm in a location w/o WiFi. It's just about finished recharging, so I plan on running the same types of usage to see how long it will last on the 2nd charge.
