I tried to downgrade using THIS thread for instructions, but now I'm bricked. Turn on the phone, black screen, metro pcs sound, nothing after that. PLEASE HELP.
Optimus M came with 2.2.1
Don`t panic it`s ok because the method does not work with 2.2.1 phones.
Just follow this guide and you will get your phone back http://androidforums.com/optimus-m-all-things-root/279318-root-2-2-1-get-data-working.html
are you sure? i don't even want root anymore, I just want my phone to work.
Yes men it happened to me a lot of times when I was trying to root. It really works
ok so I go to "Root 2.2.1 data working" and do what exactly?
follow the instructions to root?
Yes follow the whole guide and your phone phone will be back to normal.
must I do it from start to finish, or is there a point where my phone comes back and I can stop so as not to root?
Let's say this doesn't work(pure hypothetical) could I just follow the videos in "the new LGNPST Lab 1.2 thread now HD video" and use MS690ZV4_26.BIN.zip instead of the TOT file. Would that work?
By the way, you are being oh so helpful, thank you so much. truly wish I could give you money or something in return.
Yes you could use those videos but change the .bin file with the one I told you.
LOL
If all you did was downgrade it and now get the black screen you can do something much easier to get back to 2.2.1 using the lg update tool, the one you used to downgrade. Just specifiy upgrade, it will upgrade the phone back to stock.just gonna try doing everything in root 2.2.1 root get data working including the root, without changing the .bin file. practically bricked my phone trying to root, might as well get it back working AND root right? started a couple minutes ago. wish me luck If I need anything I'll message you.
Did your phone come with 2.2. It must have if you can run it an dont have black screen. You can flash the zero rom it will help with many of the issues you have if your having trouble flashing it post of specifics and there are many people that can help.New Optimus - could you clarify that? I am running 2.2 on my Optimus M and it just barely works. I just want to return the phone to original everything. I think I deleted the update tool. Market doesn't work.
