andyknights
Hi
Having discussed this briefly with SURoot - decided we needed to post to get some opinions on the issue I am having.
I've tried to root using the unrevoked guide that SURoot points to in his Rooting link in his sig and I've also tried using the Rooting for Dummies step by step guide.
Clearly I am more than a dummy (!) because I'm still not rooted....
Desire, software build 2.29.405.5
PVT1
HBOOT 0.93
Using Win7 on my laptop (x64).
Uninstalled HTC Sync from phone and laptop (but kept drivers), installed unrevoked (latest version), installed HBOOT drivers such that in device manager you can see the Andriod Bootloader interface under Android phone, cleared memory a touch (because that was a reason for one of the various errors I had along the way, I found after some digging). Then finally kept getting an error on unrevoked...waiting for device, etc
I did actually get to a point a couple of times where it said it was a triumph, but then failed later on (problems unlocking NAND flash, I recall - no idea what this means of course...) and it turns out it was not a triumph.
Tried the whole caboodle again from scratch today, but using the dummies guide, which recommended data reset (which I did, although I was scared to do so !) and all I can get from unrevoked now is either waiting for device, or communications unexpectedly interrupted. But nothing more. Ah, just got a new type of error message from unrevoked (Device "" not supported at this time...)
I'm at my wits end. I've done a partial reinstall of several applications and data so that I can at least use my phone whilst I try to sort this out (with a lot of help from some very friendly, very lovely people...), I'm just worried with my constant (unintelligent) tinkering to try to solve the issue, I might do some proper damage...
Please help me, if you can. Sorry if the above is too rambling and not helpful enough, but I'm just trying to convey as much information as possible.
Many many thanks, in advance, for any help you can provide.
Andy
PVT1
HBOOT 0.93
Andy
