sneaky_1
I can see my phone on device manager but when i run the lg flash tool and follow the steps the best i get is it saying the com port is ready after i hit the start button. I have a vm elite. Anyways when I hit start the comport says ready in yellow and then nothing. It does not start or anything. I have unplugged the phone and plugged it back in changed com ports on the flash tool as well as the computer. I run it as admin but still nothing. Am i missing a step? Thanks.
If your having issues being stuck at the press the arrow step, try unplugging the usb connector, pull the battery, reinstall the battery, then hold both volume rockers and inserting the usb cable. Once the download mode screen appears let go of the rockers.
This is assuming the flash tool, drivers and proper device manager ports are setup as per the OP's instructions.
Did you do all the steps it listed? Every single step is important including making the phone Port 41. I even had to disable the modem in Device Manager for the phone for it to work as well.
