Guys,
I've had Droid Overclock running for quite some time on whatever the preset values are for the Low Voltage setting..
I'd like to tap out as much battery life as I can from this thing - therefore,
I'd like to dabble with manually setting some lower VSELS..
I know Quickclock Advanced will automatically determine what VSELS are the lowest/safest..do i need to uninstall droid overclock before I install quickclock advanced to use the calibrating tool? or can i just install/run QC Adv. to get my phone's values, and then paste them into Droid Overclock?
Any suggestions?
thanks!
Any suggestions?
thanks!
