Root Uninstall LauncherPro from elelinux 2.2 SE :/
G8D
I just updated to the recent SE release (from the old one) and I am having issues.
I want to uninstall LauncherPro but the APK that is supposed to do so and install ADW only seems to install ADW.
How would I go about killing this app? Can it be done through Terminal Emulator?
Find LP in titanium backup, click it and you should get the option to uninstall.
I managed it otherwise, quite messily though as no downloaded widgets and certain apps are invisible, though installed.
Was Titanium set to filter ALL apps? If the filter was set to System then the symptoms you describe would occur. Similarly, User would only show user-installed apps i.e. nothing in the /system fs would show.
