Uninstalling and Reinstalling a ROM?
duga
Want to uninstall 2.1.2 and then reinstall it to see if it fixes issues in my phone. Don't want the hassle of wiping and losing my set up.
Have searched quite a lot but can't find the step by step on how to do this. All I can find is how to install a ROM.
Thanks in advance
Wipe your dalvik cache and just re-flash the same ROM.
BTW, post the issues you are having. I don't use a 2.1.2 ROM but someone else may and might be able to figure out the issues you are having. Include the name of the ROM too.
+1
I flashed and am still having the same problems. Those problems are;
-Google gps can't find a signal when I go to use it unless I reboot
-Podcasts will play but I can't forward or rewind and they work just fine on my sons stock 1.5
-Some random reboots
The rest of this rom is pretty sweat. The google gps is cool when it works and the tethering works fine. The podcast issue is a biggie for me though as I need to listen to them often to maintain first place in my fantasy football league.
Unless somebody knows a fix, it's time to do a full wipe and update to 2.3.3 or 2.4 I think
Try 2.4.0 [ROM] 08/30/10 | Fresh Hero 2.4.0 | Incremental Update For Freshness - xda-developers
