Help Uninstalling Widgetsoid
elopez15
I can't uninstall Widgetsoid with all the might I have. I've only really tried uninstalling it from market, and from the settings under applications. I've tried ATK to kill the app but it continues to run, and won't come off my list of apps. I need help getting it off without having to hard reset, i don't have it rooted btw.
those are the only two ways that i know of that you can do with out doing a reset. do you have any widgets that you created with it? maybe they are tied to it some how. when you delete it in settings/applications/manage applications and then uninstall, what does it do? does it say uninstalled? is it still in your app drawer afterwards?
I got rid of the widgets before deleting them, ive tried uninstalling under settings then applications buy,it says unsuccessful. Ive also tried reinstalling the app then erasing but that didnt work.
try powering off, wait 10 secs, reboot, then try and uninstall it in applications.
