Root Unknown error code 110
While trying to install apps on rooted htc evo 4g ... the following occurs:
1) 1st attempt to install after download get this message: Unknown Error Code During application install: "-110"
2) Re-downloaded and installs "successfully"
3) Launch application and it immediately force closes
EVO Specs:
Android Version: 2.3.5
HTC Sense Version: 3.5
ROM: EnergyROM July 4th, 2012
This is my 3rd Sense 3.5 ROM to give me the same error. Download and install of apps worked while using MikG-v3.11.signed!
Thanks in advance!
Thanks in advance!
Problem Solved. sense 3.5 is known for issues. when it works its great but when its broke its broke. You should keep in mind that Ported roms will not always support the same apps as your native roms. I have apps that If i try to put on my tablet they just crash its the same thing.
More problems then! I need to use a Sense 3.5 ROM because of exchange activesync policy bug in Sense 2.1-3.0....
Is there an alternative to a Sense 3.5 with same exchange policies?
or
Should I just got back to a rooted stock Sense 2.0 rom??
or
don't know about exchange activesync. i don't use exchange but do have a hotmail account. that i have the app for. have you tried tommy tommatoes sense 1 rom? don't know if that has it either but couldn't hurt to try
Fixed ... sorta.
So I wiped everything (x3) and went back to the latest OTA [ROM][KERNEL] 5.07.651.1 Stock - Rooted - Latest Supersonic OTA - xda-developers
Since its a Sense 2.0 ROM, exchange activesync works and so does the Play Store!
Not sure if it worked because I formatted .anroid_secure from Recovery as well.
But ultimately it is a win because taken my phone back from Sprint and all its s**tware.
Will try and re-flash a sense 3.5 ROM again and see if that works...I'll keep ya posted
