anubis2048
**UPDATED**
** 01/10/17**
STILL WORKING AS OF JANUARY 10th 2017
Credit - Me
If you are here, you must want unlimited tethering for your ZTE Zmax Pro. Windows 10 is now officially supported and this method will work on all versions of Windows above Windows 2000. This method is not recommended with games because of the very high ping.
This method is VERY fast and VERY easy if you are on the go or if you don't care for gaming.
What you need :
Windows XP or higher / Linux hasn't been tested
UltraSurf
Unlimited data plan with MetroPCS/T-Mobile/Sprint(Sprint has not been tested, but should work)
FoxFi
1. Download FoxFi and install it on your Zmax Pro.
2. Download UltraSurf to your PC
3. Start FoxFi and host your hotspot.
4. Start UltraSurf on your PC and then connect to your hotspot.
5. Enjoy
Want unlimited tethering for gaming on Steam/PSN/Xbox Live or just want to tether to other android/ios devices? Follow the guide below and watch this video.
We now have unlimited tethering again thanks to YGB and Jaykoerner!
What you need :
FoxFi(pay for it for the unlocked version, it's worth it!)
Administrator access on your PC/Mac
A PC running Windows 2000 - Windows 8.1.
OR
A Mac running OS 10.0 or newer.
Use FoxFi to launch the wifi hotspot, and on your PC you must do the following -
After your PC is rebooted, it should not use hotspot data.
YOUR PHONE DOES NOT NEED TO BE ROOTED IF IT IS THE ONE HOSTING THE HOTSPOT
For Android users you must have a rooted device and use this app :
https://play.google.com/store/apps/details?id=org.segin.ttleditor&hl=en
For Mac users
Open terminal and enter : sudo sysctl -w net.inet.ip.ttl=65
For IOS users you need a jailbroken device and a terminal emulator installed. Enter the same command used in OS X that I posted above.
Ubuntu based systems : echo 65 | sudo tee /proc/sys/net/ipv4/ip_default_ttl - thanks to MasterChief87
Hope you guys enjoy!
** 01/10/17**
Credit - Me
What you need :
UltraSurf
FoxFi
5. Enjoy
What you need :
OR
Just tried and it works! For those who dont know how (that was me a few minutes ago) here's cut&paste from Microsoft Help:
1. Open Registry Editor (regedit.exe).
2. From the HKEY_LOCAL_MACHINE subtree, go to the following key:
\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters.
3. In the right pane, add the following value:
Type: REG_DWORD
Then double click it and add value 65 as hexadecimal.
4. After that, please restart the computer and check the result.
For Mac users
