LunarCapricorn
If you are using Wifi mode on FoxFi and you have the DefaultTTL mod on your PC, there is no reason why torrenting shouldn't work. I use Tixati to torrent and I have not had a single issue.
FoxFi USB mode I don't know.
I don't know what you mean by Proxy, FoxFi doesn't have one.
I am using Wifi mode on FoxFi, and have the DefaultTTL mod. When I refer to the proxy in FoxFi, I'm talking about the option in FoxFi entitled Run Proxy. This option only becomes available after clicking to Activate WiFi Hotspot, and can be selected by clicking the button with the 3 white squares in the top right of the FoxFi screen, then clicking Run Proxy in the bottom middle. a window pops up to confirm that Web Proxy is running and says to set your computer browser to the proxy address: 192.168.1.1 port 8000. (this was easy enough for me to do on Mozilla Firefox, I just cant correctly set the proxy address in my uTorrent preferences)
So far using the "proxy option" in FoxFi and configuring my browser to match the proxy address has been the only way i've been able to successfully connect and surf on a browser, i just haven't been able to torrent yet. I'll try the client you use
----EDIT----
installed Tixati and began downoading a torrent right away without changing any config. hotspot data still not recording! problem solved, as far as I'm concerned, thanks!
