RawesomeMike
The decreased speeds I cannot explain, if I were you I would fool around with the settings more. I get full download speeds using mine. Crappy wifi cards/ routers do slow things down though. Make sure Wireless N is enabled and that your phone is near the computer. Check your laptop download speeds when on wifi to make sure that the card isn't defective or with bad drivers. I've had issues with USB wifi cards that end up having buggy drivers.
Keep DHCP on, it makes things easier without slowing anything down.
Proxy servers ONLY cover HTTP/HTTPS traffic, which 99% of what PSN uses isn't. Online multiplayer, game downloads and more will be detected. The reason you don't see the multiplayer being added is because to actually play online it only uses like what, 2-3KB/PS? You'd have to play all day just to get a few MB of hotspot usage. Hosting a VPN on your phone requires root, so you can't do that. Proxy is good for internet on Google Chrome and such.
Follow the guide again, but instead of adding a new value, just delete the one you made. Just delete "DefaultTTL" from the registry and reboot your PC. Your internet should return to normal.
I don't understand what I'm doing wrong here......okay guys I'm going to go through my struggles with you all.....Okay I started off first by modifying the APN on the ZTE ZMax Pro
Appreciate the help guys, This is also going to help anyone else who is in my shoes right now.
