I know you can't change the TTL on a Console but I feel like there has too be a way around it using a pc and some sorta data redirecting software maybe?
Anything is possible, more will be happen if your phone has root though. If your on the zmax pro like most of us, best currently is sharing it through PC via ethernet. I use wifi to my pc but I dont have a ps4 or console to try and give you my speed details. page 2 or 3, someone has done a linksys router of sorts that ttl is change-able, then router to spread our wifi and/or ethernet. supposedly it had worked but you'd need more equipment.
Upvote
0
