I did it.thanks.1. You run adb reboot recovery comand from phone, not from PC. On phone just run reboot recovey from terminal under root.
2. If you use CWM from first post, it CAN'T DO wipe after you pres Yes for Factory reset.
Try to install and removeCan you port this to LG L40 D160, please
I think in kernel. But I don't have (not even seen) d160...Whats the wifi's file location? im using d160 and i flashed cm 11 but i cant find the wifi file
jThe recovery linked in OP doesn't work on my D160. Dose it work on someone else's here?
I haven't unlocked the bootloader befor flashing the recovery, that's probably why.j
Works well on mine d160.Cnt help you without any details.
Impossible for me without device...Could you port this Rom to lg
d160 please? I love this rom
but in my lg not work very well.
It has some bugs like the
camera and wifi
I've got a D160, unfortunately I can't give it away. Would it help to have an image (or one per partition) of the internal memory? Could also offer you an adb connection to it over ssh.Impossible for me without device...
That looks good, thanks!Try what he shared https://yadi.sk/d/Zusy6xetfyszb
I'm slightly unsure as to what's the correct way to install that. I figure that's the .zip which i'd eventually apply as an update from my sd card (been there while rooting). Do I still need to go through the "install bootloader" and "install CWMR" steps, and if so, using the D170 files for those (as listed in the first post)?fstd said:I am somewhat new to the Android world though
