I can't do it without device.I have a question, will i as a LG d160 owner be able to use this rom, i mean while it ever be optimized for it?
I've used it before, but you probably already know from my previous posts that WiFi and camera don't work, personaly i dont care about the camera cause its bad anyway.
Files i can get myself. For development device should be in the hands.What do you need from the phone, i mean i can give any files or anything through internet except the phone itself.
Dear to explainTry to install and remove
persist.radio.multisim.config=dsds
line from /system/build.prop
دمت گرمه داداش سعیدسلام علی
شما رام رو نصب کن بعد از داخل فایل Build.prop توی پارتیشن سیستم خط زیر رو پاک کن.
tnx so muchچون شما گوشیت دو سیمه باید این کار رو انجام بدی تا رام برای گوشی های تک سیم بشه. احتمال هم داره که Wifi درست بشه.
you have to do it because you phone is single sim model, this work makes CM11 works with single sim.
perhaps your Wifi should work now.
I'm not planned cm11 updates.Hello ????
Anybody here ??????
i want update for this ROM
Yes. But CM11 upstream not update. And I not have device specified changes for cm11.you know this Rom is the only daily use and fastest rom ever for this little smart one.
Hi!نمیدونستم
الان دیگ حله
I think it easy for you if you have this device. But it impossible for me, I don't have this device, I don't have CDMA network...any chance of porting to LG34c or the CDMA variants of the d170?
CyanogenMod 11 for LG L40 D170
View attachment 78792 View attachment 78793 View attachment 78794 View attachment 78795 View attachment 78796 View attachment 78797
My port of CyanogenMod 11.0 for LG l400 D170. It is unofficial and unsupported by the CyanogenMod team.
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and CWM recovery.
Working:
Not working:
- Display
- touchscreen and multituch
- Hardware 3D rendring
- RIL, DualSIM, SMS, MMS, calls, mobile data 2g 3g, etc
- WiFi
- GPS
- Bluetooth
- WiFi, Bluetooth, USB tethering
- Audio - speaker, headphone, mic, routing, voip calls, etc
- Camera - photo and video
- SD card
- FM radio
- Hardware video decoding and encoding
- Sensors
- Double tap to wake
Download
- FM radio without headphones
Bootloader https://yadi.sk/d/Eob7iYsWdRR5m
CWM Recovery https://yadi.sk/d/XhPf01TNdRRJx
cm-11-20160113-UNOFFICIAL-w3ds.zip https://vasy.ru/CyanogenModOTA/builds/full/cm-11-20160113-UNOFFICIAL-w3ds.zip
Gapps http://forum.xda-developers.com/showthread.php?t=2397942with internal SD card:
cm-11-20150907-UNOFFICIAL-w3ds.zip https://yadi.sk/d/RZTQy3DniwjVV
only external SD card:
cm-11-20150906-UNOFFICIAL-w3ds.zip https://yadi.sk/d/poPWcM0miwjWa
cm-11-20150729-UNOFFICIAL-w3ds.zip https://yadi.sk/d/MJ7N6FnNiBQEz
cm-11-20150730-UNOFFICIAL-w3ds.zip https://yadi.sk/d/1FMegliqiBQFZ
cm-11-20150325-UNOFFICIAL-w3ds.zip https://yadi.sk/d/i9eHiv9ZfXd8n
cm-11-20150215-UNOFFICIAL-w3ds.zip https://yadi.sk/d/C0DZhEqsehf94
cm-11-20150110-UNOFFICIAL-w3ds.zip https://yadi.sk/d/7Dw-uTgadvX4f
cm-11-20150104-UNOFFICIAL-w3ds.zip https://yadi.sk/d/mztw-aVsdnE22
cm-11-20141213-UNOFFICIAL-w3ds https://yadi.sk/d/XntF1I61dMzFk
Source
Kernel https://github.com/vm03/android_kernel_lge_msm8610
Device https://github.com/vm03/android_device_lge_w3ds
https://github.com/vm03/android_device_lge_msm8610-common
Proprietary https://github.com/vm03/proprietary_vendor_lge_msm8610
- adb shell
- su
- dd if=/dev/block/mmcblk0p6 of=/sdcard/abootstock.bin
- exit
- exit
- adb pull /sdcard/abootstock.bin
- adb push aboot.bin /sdcard/
- adb shell
- su
- dd if=/sdcard/aboot.bin of=/dev/block/mmcblk0p6
- exit
- exit
- adb push recovery_lg_d170_cwm03 /sdcard/
- adb shell
- su
- dd if=/sdcard/recovery_lg_d170_cwm03.img of=/dev/block/mmcblk0p17
- exit
- adb reboot recovery
- Copy zip's to SD
- Enter to recovery
- wipe data
- install zip from external_sd cm-11<...>.zip
- install zip from external_sd gapps
- reboot
Donate
- CyanogenMod Team
- Quarx
- Andrew-New
