Will try, but how do I backup my modem MS323? Will be happy to if there's a way to.
Code:
dd if=/dev/block/platform/msm_sdcc.1/by-name/modem of=/storage/sdcard1/modem.img
@vm03 Your MS323 IS ON ITS WAY!Anyone have the original camera apk from the stock ROM? Because the camera on CyanogenMod 12 doesn't do full resolution THANKS![]()
Can you confirm my original quirey@vm03 Your MS323 IS ON ITS WAY!
http://androidforums.com/threads/still-trying-to-send-vm03-a-ms323.905195/
Check the last respondces.![]()
Alright, first. Quoting me to answer a question from a nother is NOT okay. I saw your question when posting the MS323 post. I don't have it. I don't know where do find it. If I don't answer a question it usually means I don't know the answer.Can you confirm my original quirey
Does it will ever work with CM?Anyone have the original camera apk from the stock ROM? Because the camera on CyanogenMod 12 doesn't do full resolution THANKS![]()
Well I'd like to try so if someone has the apk I'd be greatfulDoes it will ever work with CM?
Here you go, download with megaWell I'd like to try so if someone has the apk I'd be greatful
Thanks. I'll give it a try and report backHere you go, download with mega
https://mega.co.nz/#!7FF0jDgJ!WWQalj_JcIYrg8OPX3Y_AvqLIPVvmTn-GGIszaTlvgk
You can try XCam LGOK it installed but crashed on opening. Thanks anyway
Thanks for the suggestion. I'll try it tomorrowYou can try XCam LG
Or lgcamera pro works well for meThanks for the suggestion. I'll try it tomorrow
Apk?Or lgcamera pro works well for me
I think this problem have only you.I have the d320n on new Zealand carrier. It only happens sometimes I can make calls most times. What is aboot.bin, is it to do with when flashing twerp because I fastboot flashd the one supplied. Please could you clarify what the aboot.bin file does, and how do I check for the correct one
Thanks![]()
Here and on CM12 thread is this writed 100x maybe more.Hey how do I manually update to the new ota enabled version, cab I skip Versions right up to it? Any problems with the new update on the d320n?
That's cool thanksHere and on CM12 thread is this writed 100x maybe more.
Just flash it.
No, any problems.
