Tweakforce_LG
Hey every time i download the cm12 the md5 is different and wont flash so installing cm12.1 from here has a better chance?
OTA some times latter.@vm03 can you please build new version or make OTA like in cm12? Thank you![]()
Ok, thank youOTA some times latter.
first flash rom, finish setup wizard and after this flash gapps and wipe cache/dalvik && rebootThe Newest build (20150411) always crash at setup wizard for me (D325), cant even get on launcher.
The only solution for me is install 20150403 build (wipe and everything, flash gapps too), get pass setup wizard then upgrade without wipe 20150411 build.
Try another GAPPS. And use latest TWRP!The Newest build (20150411) always crash at setup wizard for me (D325), cant even get on launcher.
Call recording is illegal in some countries... That's why they haven't enabled it...2015-04-16
May be fixed UI FC... Test on ms323 and say.
- Enable call recording
It's illegal if other party doesn't know the call is being recorded. That's why on most call recording programs there's an obligatory "beep" at the start of recording. I guess it's the same case in cm12.1.Call recording is illegal in some countries... That's why they haven't enabled it...
I not sure there is such a thing in cm12.1 that's why I say I'm guessingI didn't knew anything about beep in cm 12.1... :/
In cm 12 I used that and there was nothing notifying second person that someone is recording...I not sure there is such a thing in cm12.1 that's why I say I'm guessing![]()
Now that's illegalIn cm 12 I used that and there was nothing notifying second person that someone is recording...
I'm using latest TWRP, and using Gapps on first post. It looks like I should check another gappsTry another GAPPS. And use latest TWRP!
I install xposed module to enable it... Never used it...ledosladoledi
Do not use the function of call recording, if you feel guilty.
Does the latest build have OTA Update? If not how should I install future updates? Do I have to clean install it or just flash it over the older 12.1?2015-04-16
Just flash new one over the older 12.1.Do I have to clean install it or just flash it over the older 12.1?
Call recording disabled for this countries by mcc. Currently call recording enabled on official cm's.Call recording is illegal in some countries... That's why they haven't enabled it...
Currently no OTA.Does the latest build have OTA Update? If not how should I install future updates? Do I have to clean install it or just flash it over the older 12.1?
