Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
I played TASM 2 on this ROM and it's lag like hell, this is also happened to CM 12
But, it's smooth like butter when on CM 11 or stock rom
Just reporting
Go to ”Developer Options” and tick ”Disable HW Overlays”.
Hi,
@vm03 can you please sync & build new rom with updates?
Thank you :)
edit: tomorrow or in 2 days i post here bugs what i find.
CM12 newer be stable as cyanogenmod team say. Today my device is hard crashed without reason... :D And i'm back on cm12.1
on D320 every thing work good :), but a little bug when set brightness to minimum and screen turns off, screen not turn on again for some seconds.
thanks for sharing this rom, great rom!
I'm back with the necessary corrections. Thanks to member and developers, tools, files made available by all, managed to install my ROM. I mean this quite stable and light, everything I imagined. I thank you all.
I'm tempted to go back to stock because of the camera error, But this rom is so smooth
and somehow I think everything looks better including 3D games.
So, is the camera going to be fixed in coming updates? (Not that I'm super desperate or anything)
Anyway, Should I stay for a while on this rom or go back to stock while the camera
gets fixed?
On another note; No errors or serious bugs so far, The signal icon just keeps displaying a "!" sign
to the side and turns normal when I turn on WIFI but that's all I have noticed for now... Only had
on reboot I think.
gets fixed?
on reboot I think.
That's an indicator that there's no data connection, not a bug. About camera... Until vm03 receives ms323, I don't believe.
Ok, Gotcha. For now I'm back to stock rom and rooted via blue drake script.
I'll keep a close eye on this rom for a while since I really liked the performance
and looks.
Bug list:
  1. when i try lock screen with brightness on minimum, brightness is set automatically for 1 second to maximum
  2. Not showing signal icon
That's all i think for now.
Bug list:
For nr 2 i had the same issue and one day the phone got stuck and had to reboot it and the signal went back all by its self
Probably it's random. Sometimes i have signal icon too, but it's very random. And it's only "pretty face" bug, not important :)
