Why are you asking this here exactly? If you deleted your Stock ROM then you're out of luck unless you wanna go back to stock then backup then come back here.Hey how do I get my stick ROM back just incase. Nandroid makes it not boot
thanks, im guessing lg flash tool recovers the partitions to stock, and the nandroid didnt work bc cyanagenmod partitions are different? is that right?Why are you asking this here exactly? If you deleted your Stock ROM then you're out of luck unless you wanna go back to stock then backup then come back here.
Restore the LAF with the LAF Multitool
Then use the LG Flash Tool 2014 with your KDZ.
boom. you're in stock.
Not really. It just restore's stock since LG making hard things hard puts .kdz extenstions and they can only be flashed via the flash tool.thanks, im guessing lg flash tool recovers the partitions to stock, and the nandroid didnt work bc cyanagenmod partitions are different? is that right?
Does not work. Still UI FC. Here's my logcat:
D/QSEECOMAPI: ( 6735): QSEECom_get_handle sb_length = 0x2000
D/QSEECOMAPI: ( 6735): App is not loaded in QSEE
E/QSEECOMAPI: ( 6735): Error::Load image request failed ret = -1, errno = 14
E/QSEECOMAPI: ( 6735): Error::Loading image failed with ret = -1
E/QSEECOMAPI: ( 6735): Error::Cannot open the file /firmware/image/keymaste.mdt
E/QCOMKeyMaster( 6735): Loading keymaster app failed
E/keystore( 6735): could not open keymaster device in keystore (Operation not permitted)
E/keystore( 6735): keystore keymaster could not be initialized; exiting
D/QSEECOMAPI: ( 6743): QSEECom_get_handle sb_length = 0x2000
D/QSEECOMAPI: ( 6743): App is not loaded in QSEE
E/QSEECOMAPI: ( 6743): Error::Load image request failed ret = -1, errno = 14
E/QSEECOMAPI: ( 6743): Error::Loading image failed with ret = -1
E/QSEECOMAPI: ( 6743): Error::Cannot open the file /firmware/image/keymaste.mdt
E/QCOMKeyMaster( 6743): Loading keymaster app failed
E/keystore( 6743): could not open keymaster device in keystore (Operation not permitted)
E/keystore( 6743): keystore keymaster could not be initialized; exiting
Ok, i think @vm03 have this "bug" on to-do list.Hey can someone help. The battery animation is missing when charging with phone off. I don't mind that but the screen won't turn off witch I'd like. Any info or dumps I'll upload if needed
I can always boot into twrp and charge because the screen times out on that
@vm03, I'll upload modem for d320n in a jiffy, just wait a second.Does not work. Still UI FC.
OK, this is golden, I lost it hereBest hotfix is charging when is your device turned on.
You need to register on the site 4pda
You should post is somewhere else also, yandex or google dirve for example, because most of users can't register. The main problem is cyrilic captchaTopic: Disabler Internal SD for CM12.1
http://4pda.ru/forum/index.php?s=&showtopic=648764&view=findpost&p=39315229
Can you try to flash modem.img from d320? After it may be ril not be worked(until replace the original) , but we get more info for thinks.Code:D/QSEECOMAPI: ( 6735): QSEECom_get_handle sb_length = 0x2000 D/QSEECOMAPI: ( 6735): App is not loaded in QSEE E/QSEECOMAPI: ( 6735): Error::Load image request failed ret = -1, errno = 14 E/QSEECOMAPI: ( 6735): Error::Loading image failed with ret = -1 D/QSEECOMAPI: ( 6735): QSEECom_get_handle sb_length = 0x2000 D/QSEECOMAPI: ( 6735): App is not loaded in QSEE E/QSEECOMAPI: ( 6735): Error::Cannot open the file /firmware/image/keymaste.mdt E/QSEECOMAPI: ( 6735): Error::Loading image failed with ret = -1 E/QCOMKeyMaster( 6735): Loading keymaster app failed E/keystore( 6735): could not open keymaster device in keystore (Operation not permitted) E/keystore( 6735): keystore keymaster could not be initialized; exiting D/QSEECOMAPI: ( 6743): QSEECom_get_handle sb_length = 0x2000 D/QSEECOMAPI: ( 6743): App is not loaded in QSEE E/QSEECOMAPI: ( 6743): Error::Load image request failed ret = -1, errno = 14 E/QSEECOMAPI: ( 6743): Error::Loading image failed with ret = -1 D/QSEECOMAPI: ( 6743): QSEECom_get_handle sb_length = 0x2000 D/QSEECOMAPI: ( 6743): App is not loaded in QSEE E/QSEECOMAPI: ( 6743): Error::Cannot open the file /firmware/image/keymaste.mdt E/QSEECOMAPI: ( 6743): Error::Loading image failed with ret = -1 E/QCOMKeyMaster( 6743): Loading keymaster app failed E/keystore( 6743): could not open keymaster device in keystore (Operation not permitted) E/keystore( 6743): keystore keymaster could not be initialized; exiting
Will try, but how do I backup my modem MS323? Will be happy to if there's a way to.@vm03, I'll upload modem for d320n in a jiffy, just wait a second.
I believe 3G or WCDMA (or whatever they call it there in America) won't work.
EDIT:
https://drive.google.com/open?id=0B_IkPSHLrYQfeEQ5TlVadTYtVW8&authuser=0
Anyone willing to test it on ms323, here's modem for d320n, as vm03 suggested.
Be sure to backup your current modem before flashing so you can restore.
I can mirror it if you agreeYou need to register on the site 4pda
404 error?Topic: Disabler Internal SD for CM12.1
