Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Hi! How to make te corrección of aboot.bin? The update ota is ver y well, my device is d320f8, all correctly work, only the CPU is on high temperature... Thanks #vm03
hi my friends.i installed this ROM (LG L70 D325) but touch screen is not work and i can not complete set up wizard without touch:( how can i solve this? :((
have you right aboot.bin & new twrp?
and do you have only d325 or d325(number) ?
i dont have twrp .i installed it with cwm recovery.its D325f (it wrote on back of the phone and near the camera) i just installed the rom and i dont change anything like aboot.bin
how i can flash it? i dont have twrp installed .and i cant access my phone to install it .it stays in setup wizard !
copy cm12 or any kk rom to your sd card and flash it from recovery
after this open flashify from google play and flash twrp
after this flash cm12.1
you're done
Those of you having setup wizard crash in D325 just swap a sim and complete the setup and and insert sim again! that's it!!
you're done
i said that my phone stay in setup wizard and touch screen doesnt work and i cant complte the setup wizard to use the phone and download flashify !touch screen doesnt work at all ! just voloume keys and power work.
my tutorial is without touches on screen...
everything what you need is computer & sd card
oh now i remembered that i wanted to install twrp recovery and i think i mistake and after that it goes twrp but the touch screen doesnt work there.after that i installed cwm and installed the cyanogen 12.1 rom .but in setup wizard the touch screen doesnt worked at all.all of this is because of that mistake . is there any way to solve it? sorry for my bad English friend
because of touch screen not working my phone stay here and i cant continue the setup wizard
is there any way to install it without having any custom recovery? my d320n does not want any of the recovery thingys.. after i flash them and try to boot i get a stupid purple screen with some error text. i had to reflash my phone with lg flash tool and a stock kdz 4 times tonight trying to get a recovery working. i have no idea why. i tried it installing manually, with the loaders, even with the automated laf recovery tool. nothing worked. i seriously doubt that my phone wants me to upgrade it at this point.
any help would really be apreciated given that this is my first time actually resofting androids.
http://androidforums.com/threads/twrp-ms323-d320n-d325-team-win-recovery-pro-2-8-6-0.911656/
use this link.
Okay. Let me explain. I started off rooting my phone with
http://androidforums.com/threads/guide-root-root-your-lg-l70-ms323.853477/
after that i unlocked bootloader like it was said here
http://androidforums.com/threads/unlock-lg-l70-bootloader-unlock.862585/
then i installed twrp.
When i tried booting in recovery mode i got an error of about 3 rows over the lg logo, and after 2 seconds my screen turned purple. I tried restoring the laf but that did nothing. I had to resoft my phone using
http://lg-phone-firmware.com/index.php?id_mod=52
and the lg flash tool 2014 to actually be able to go back in the default recoverymode.
I repeated all those steps for all 3 versions of modded recovery mode. I even tried earlier versions. All to the same outcome.. And after doing this last night and today for about 5-6 times, i'm kinda sick of my phone and would like to throw it as hard against a wall as posible.
So, my question is: did anyone else ever bump into this purple screen? and how did you manage to get rid of it and actually get in a recovery mode to be able to install this rom?
I had that screen when using flashify. Use fastboot to flash the recovery.img
I'm not knoladgable of the laf tool so I cannot help sorry. Maybe ask someone if its to do with having the incorrect aboot.bin but I don't know much about that either sorry. All I can do is suggest what to ask others :)
