Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Do you have proper aboot? Someone with ms323, give this man a proper aboot.
As i said.. this is my first time getting hands on with a custom rom and i think i never saw in any of the indications something about aboot.(that felt weird to write:D) Anyway, i have a d320n, don't think ms323 is gonna do me any good.
Sorry to nag you guys about this, But I guess the rear camera still doesn't work? I just read the
first post and it looks that way. I have an LG L70 D320n (f8 mexico) and the rear camera doesn't
work on this model.
No biggie tough, I have setup my phone to be ready to flash this room when an update with working
camera comes. I really liked the performance of lollipop and no bloatware or unneeded apps on
this rom which is great!
work on this model.
on f8 is camera not working.
Yeah, I read that on the first post. I tried the current version a few days ago and the
camera FC's when switching to the rear camera but works finw with only the front
camera.
Even though I know this isn't for the "ms323" I tried it anyway. Everything worked awesome for about an hour(except the rear camera of course), but then once I got all my apps restored, it just kept crashing, maybe because I had tons of apps on there and I guess the "CM Updater" takes up a bunch more room on the internal storage. I may have just ran out of space.
The new Lollipop interface is SO COOL though and I love that you can take OTA updates for CM. I so wish someone would port this for the "ms323"!!! If I had the know how I would, with permission from the OP, do it in a heartbeat for all of you ms323'ers out there. Great work vm03! :)
I also had this problem. I restored laf, went to stock, unlocked bootloader and flashed recovery by ADB.
Attached the zip. There are some instructions.
You can do it my way.
FLASH Recovery TWRP 2.8.6.0 and unlock bootloader
- Link: https://drive.google.com/file/d/0B5WRInBhq8eqX19ZaHRtVDZ5a2s/view?usp=sharing
1. Extract file
2. Copy folder l70twrp to C:\
3. Run Flash.bat from C:\l70twrp to flash TWRP 2.8.6.0 and unlock bootloader
Run Flash_re.bat from C:\l70twrp to flash TWRP 2.8.6.0
Run RR.bat from C:\l70twrp to reboot recovery
@vm03 , I used this rom (22-4-2015) for 2 days. it very wonderful. But, it have some error.
- Sometime, Apps auto stop when open, but reopen after (including system app).
- my calendar app can not add event. I login to cyanogenmod account and sync to view but it loading only.
- status bar with battery status style is circle and battery percent is inside icon, but it is "%" only.
- CM update detect fail new update. it detect version 22-4-2015.
Sorry, my English is bad.
LG L70 D325 Dual
Cm 12.1, 22-4-2015
hi friends.when i want to install twrp it shows this in my phone and because of my touch screen is not working i cant choose ok to continue installing twrp.what should i do now?(without touch screen)
you can't.
Why, you don't flash CM11?
Try installing from fastboot.
Since the last 3 (don't remember exactly) builds of CM12 and all of 12.1 my home button doesn´t work, the menu button works as home, i had a d320f8 it can be fix it? i need to do something? is not a big deal but it will better working all buttons
