moedjs
It's already there from first buildI have noticed that from latest build i can choose between internal memory and sd card in some apps, which is pretty cool...![]()
This is here from first build of CM12.1 i thinkI have noticed that from latest build i can choose between internal memory and sd card in some apps, which is pretty cool...![]()
It was present of some of 5.0.2 roms even (nameless, PAC)This is here from first build of CM12.1 i think
Yes, you're rightIt was present of some of 5.0.2 roms even (nameless, PAC)
If you have rooted your stock rom and are happy with the stock rom. Dont worry. Just enjoy rootIf i choose to don't do this is there any problem? It seems too complicated to me?
I tried it, but I was getting bootloops. (But I installed alot of modules with it and didn't figure out which one is working and which one does not.) Check the questions and answers of that web page I saw someone made it work. But you have to delete some files from system before each reboot. Cheers hope this helps.Is here any brave soul and can try this?
http://forum.xda-developers.com/xposed/super-alpha-posted-permission-xposed-t3072979
What if i want to install a custom Lollipop rom will allow me to do it?If you have rooted your stock rom and are happy with the stock rom. Dont worry. Just enjoy root
Why nobody read threads about lollipop roms, before asking same question again, again?Is it possible to flash Torch to this CM12.1 and add it as a tile? I miss having the convenience of an integrated flashlight and tile that can be toggled, added/removed..
Also, how can I re-root this? Lost root since I nuked stock ROM. I can't TowelRoot it because I can't access Settings > Security > Unknown Sources to toggle it on. Trying to access Settings > Security crashes every time I try to access security. I updated via OTA to the latest CM12.1 build.
Check this link, for working xposed modules and non working xposed modules on Android 5.1 Xposed. I m going to try right now and update soon. Cheers...........hope this works.I tried it, but I was getting bootloops. (But I installed alot of modules with it and didn't figure out which one is working and which one does not.) Check the questions and answers of that web page I saw someone made it work. But you have to delete some files from system before each reboot. Cheers hope this helps.
Check my feedback on nameless ROM, If it works on Nameless it should work on CM12.1 as well. Enjoy.Check this link, for working xposed modules and non working xposed modules on Android 5.1 Xposed. I m going to try right now and update soon. Cheers...........hope this works.
Rom is rooted, just flash super su.
Probably error is between device and your handI'm not rooted. ES root test failed.
Because if you flash supersu, you have full root control on your device
Or simply enable root access under "Developer Options"I just need to flash latest SuperSU from Chainfire or flash a specific SuperSU for L70 MS323?
SuperSU is better than this buildin option.Or simply enable root access under "Developer Options"
To access developer options, go to settings>about phone and tap quickly and multiple times on "Build Number". Go Back and You will find Developer Options (in the settings app).
In Developer Options there is an option that gives root to apps and adb.
you should use correct aboot.bin and TWRP. search the forum. you'll find itCan anybody help me? I try to reassign the capacitive buttons editing Generic.kl , but this is not working. In D320f8 menu button acts like home
You can try it, but you can hardbrick your deviceWill the TWRP work with the LG Ultimate 2 (LG L70c)?
Oh well. I need to unlock the bootloader first.You can try it, but you can hardbrick your device
Nobody here know if it working.
