Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
now im on cm12, there is notification about cm12.1 updates. should i just auto update or manually flash it with recovery? and which custom recovery should i take ? cwm or twrp
I just realized that MultiMount SDCARD only mount the sdcard READ-only, with cm12.1
Can't transfer file from PC with UMS anymore
While MTP mode always crash in the middle of transfering large file
My MS323's still booting at the CM logo boot animation screen.
I flashed these from my 64GB MicroSD, in this order:
cm-12.1-20150502-UNOFFICIAL-w5.zip
gapps-L-4-21-15.zip
UPDATE-SuperSU-v2.46.zip
How long's it supposed to take for first boot?
It's taking way longer than usual.
gapps-L-4-21-15.zip
Just wait. It takes about 7 minutes.
Still booting?
Updating partition details...
unable to mount data, cache, system.. I'm guessing this is bad, right? The ROM flashed successfully. I'm going to try flashing the gapps after. The slightly older mini gapps I tried flashing failed to flash.
I'm going to try the gapps you linked.
... And, yet, these settings still crash even after wiping for for a fresh/clean install... Security, Lock Screen > Screen Lock
gapps-L-4-21-15.zip
From my experience, NEVER flash SuperSU. It causes a bootloop/soft brick. Just flash CM and GAPPS and enable root in Development settings.
It's ok.
First flash rom, make install wizard and after flash gapps, wipe dalvik and reboot. Wait, and after boot to recovery and flash supersu. This can't make bootloop
