Tweakforce_LG
Any reason why music keeps crashing when trying to play a mp3?
Have you flashed new twrp?on my d320n still some problems.
aosp keyboard and data usage still fc.
Search on this forum... Why is everybody so lazylink ?
Make a complete wipe, flash CM, boot, finish instal wizzard & reboot to recovery, flash gapps & reboot, after this, reboot to recovery and flash supersu, maybe can help. on my d320n is everything working wellI'm not lazy,i'm just out of my bed
I'm using 2.8.6.0 twrp ,it's the latest I thought.
That's battery saver, I think you can turn it off or at least lower it to 5% in settings. But it ahouldnct give you black screens...Never mind foxed
Replugged in the sd card.
But on anithrr note. When the phone hets to about 12% power the screen turns off and wont turn on. When the phone restarts it cuts out. Is this a rom problem or is battery calibration screwed? Thanks
Right aboot.bin & twrpAnybody knows how I can fix the buttons in D325? anything button work I'm using the virtual buttons in the moment, help..
Now I reinstal with twrp and buttons continue not work, D325F8Right aboot.bin & twrp
The same with me when I update to last build my version is D325F8Is anyone experiencing/having these: Bugs/issues/problems?
- Reboot when trying to uninstall apps, usually apps that were installed from Google Play Store.
- Stuck booting after root uninstalling system apps via ES File Explorer/Manager.
CM12.1'll get stuck at either:
Boot logo screen.
Optimizing apps > Android is starting... Starting apps, and, it never budges from there. So, I wipe, and, re-flash the latest CM12.1 nightly.
I keep flashing/re-flashing:
cm-12.1-20150502-UNOFFICIAL-w5.zip
pa_gapps-modular-nano-5.1-20150315-signed.zip
CM12 (12.1) use for installing not format and copying files, but flash img file. Size defined in BoardConfig, if I increase size, we can't use resized partitions. You can try backup by TWRP, format system, restore system from backup.Is this supposed to happen? (I'm using MS323) /system is clogged. Even though I wiped /system during install. Also, isn't it more system space? (Used to be atleast 700mb of /system storage than 500mb.)
I'm using Pico GAPPS. By the way. Y'all thinking I installed something like the full package.
